Intermittent coolant warning
poddack
Post by poddack »
If your radiator symbol flashes occasionally and you have plenty of coolant, take out the sensor from the bottle and clean the dirty prongs!
Hmmmm, straight 6 goodness!
carlb
Re: Intermittent coolant warning
Post by carlb »
hi are you sure its the rad symbol and not the water in diesel sensor in the filter housing
as i havent heard of the coolant level sensors giving any problems
RayneR
Post by RayneR »
carlb wrote:hi are you sure its the rad symbol and not the water in diesel sensor in the filter housing
i suppose that the sensor for water in diesel filter is not fitted to all cars am i right ?
2000/May 406 Estate 2.0 HDI 110bhp DW10ATED now with 205k km & now with cruise control & now remaped @ 134bhp :lol:
OdinEidolon
Post by OdinEidolon »
Mie doesn't have it acording to servicebox
carlb
Post by carlb »
i see i have just looked at mine and it hasnt got one so it may not sory
RayneR
Post by RayneR »
Yep, mine doesn't too ..anyway there is some stuff that servicebox is not 100% accurate ...
poddack
Post by poddack »
It was definately the radiator symbol, after cleaning the prongs it hasn't done it since.
There is no water in diesel sensor on mine, but there might be a wire for it.
RayneR
Post by RayneR »
Does anyone here have one with this sensor ? Do you know what it is? have pictures ? Could this be retrofit ?
