Can the fuel pump/ECU relay intermittently die?
lakemaligne
Post by lakemaligne »
Is it possible for the double relay which sits next to the ECU,which powers the fuel pump and ECU, to fail momentarily,causing the engine to suddenly die,or try to die.?
MK1 1996 2Ltr 16v Petrol LX, 167,000 miles,was aiming for 200,000.
plod
Re: Can the fuel pump/ECU relay intermittently die?
Post by plod »
Not had it on the pug, but had similar on a poxhall years back which was the fuel pump relay playing up
Seal on it had cracked and was allowing moisture inside and causing corrosion
1999 D8.5 HDi GLX - Sold :(
