wiring colour to radio connector?
- Newbie
I have been having some issues with my Sony CD/radio in the fact of the clock/power going on/off, so what do you do, you pull it out and have a look at it, and the connectors have worked loose, worse they are off all together, so i don't know which is which?
going into the main dashboard connector plug is 4 wires:
Yellow
Brown
Orange
Purple (light purple?)
which is which (power/earth so on) I don't have any problems with the speaker connections as they are still tight, if i know which colour is which, then i should be able to reconnect the power....
Model is a 1996 2 litre sedan (manual), in excellent condition (and yes i have replaced my timing belt)
Yellow
Brown
Orange
- DiscoPol
- Shiny New C5 2.2 Bi-turbo!
Re: wiring colour to radio connector?
Firstly, Hello and welcome,
now on to your problem, you cant really trust the colour coding on Peugeots they are not the most consistent of car manufacturers with the wiring, they are French after all, do you have a multimeter? or access to one? i think its going to be wise to use one to find the constant live, switched live and neutral.
sorry not a lot of help really, maybe somebody will be along soon willing to take a punt at what wire does what
- Newbie
Sorry I don't have access to a multimeter, if there is two live's (constant and switched (that is the one that goes through the ignition key correct?)) that would make it difficult to work out which is which, but knowing the wires would help,DiscoPol wrote:Firstly, Hello and welcome,
thanks for your reply
You run an old car but don't own a multimeter?
Go buy one, it doesn't have to be amazingly accurate and they're cheap as chips!
Pug don't even use colour codes, you need to read the numbers off the wires for us to make any sense of them.
Hello & welcome
It's a radio Disco, not a ceiling rose!DiscoPol wrote:find the constant live, switched live and neutral.
- Newbie
Ok Here we gosteve_earwig wrote:You run an old car but don't own a multimeter?![]()
Yellow: M841
Brown: A16
Orange: V19Y (wire is quite thin, so is hard to read)
Light Purple: B25
Here we go, thanks again
- DiscoPol
PEDANT! and no i dont mean pendantdogslife wrote:Hello & welcome![]()
Ahem! I'm reading that as:
M - earth
A - accessory +ve
V - lighting
B - +ve
That seems to be the way it goes but I'd rather you check it with a multimeter...
M - earth
A - accessory +ve
V - lighting
B - +ve
- Newbie
Thanks for that stevesteve_earwig wrote:Ahem! I'm reading that as:
M - earth
A - accessory +ve
V - lighting
B - +ve
One last question...what is +ve, is that live? (you can see now why i don't have a multimeter, but will get one, and the other reason I bought a Peugeot, I rarely have to put a spanner to it, except for wearables)
Thanks to all for the help....
Yes, that's live, if you like. Not 240 volts though...
- Newbie
Thanks steve
The wire coding was correct!...Eric Clapton (god) is back on and better than ever...thanks to all.....no doubt i will be back.
