HELP!!! Nothing works until ignition on
sfreeman66
1.6 8v
Post by sfreeman66 »
Hi All,
I have lovely problem for a saturday afternoon (joy i could be relaxing and putting my feet up instead lol).
We have a 406 diesel estate which managed to get stuck in a field, in an attempt to get it out, it was rocked on the starter. which unfortunately didn't work and burnt out the starter and the lovely Green Flag Man had to recover it.
We have fitted a new starter motor and she now starts all ok, however we now have no power to dashboard lighting central locking, lights, hazards, radio until the ignition is switched on with the key. we have checked the igntion switch wiring and this appears to be all ok and checked all fuses.
we are wondering if maybe something like the built in interface system maybe the culprit.
Has anyone got any ideas or suggestion please.
Yours hopefully
Sammy Squirrel
Re: HELP!!! Nothing works until ignition on
By checking "all" the fuses, did you remember the one or two engine bay fuseboxes, as well as the one under the dashboard?
If you're certain the fuses are good, I'd be looking at relays.
sfreeman66
1.6 8v
Hi
Running out of ideas, all relays and fuses checked, rang Peugeot workshop today and foreman suggested amother thing to try, ie multiplug under carpet under throttle pedal, apparently common fault as water tends to get into it, but that is all ok.
We have put it on computer today and cleared all fault codes but nothing relevant held in memory.
Looks like we have just lost a live feed and its gonna take a while to find!!
When you say you checked the ignition switch wiring, did you check the switch itself with a meter?
sfreeman66
1.6 8v
Yes the feed through the ignition is all ok and been checked with meter, we have discovered that if we remove one of the plugs (yellow) on the BSI everything works properly, could the power be going in the wrong way???
Totally dumbfounded, we are reduced to head scratching at the moment!!!
Perhaps a fault elsewhere is triggering some sort of safety mode :? Dammit, the yellow connector is 26 way, there's no way I can follow all that to narrow it down :(
sfreeman66
1.6 8v
Yep, similar conclusion here, we have been busy poking and hoping, but to no avail, strong coffee, bed and then we shall try again tomorrow, maybe we'll get some inspiration to solve the mystery, if not back to the poking and hoping!
I thought of a different way:
26V JN
01 C001 : diagnostic connector
02 1620 : vehicle speed sensor
03 1320 : engine management control unit
04 1320 : engine management control unit
05 8025 : air conditioning panel (if separate)
06 1320 : engine management control unit
07 0005 : screen wiper switch
08 0005 : screen wiper switch
09 spare
10 0005 : screen wiper switch
11 0005 : screen wiper switch
12 0002 : lighting and signalling switch
13 5015 : windscreen wiper motor
14 1030 : engine-on information relay
15 8220 : analogue module transponder (speedo??)
16 1320 : engine management control unit
17 8220 : analogue module transponder
18 spare
19 0005 : screen wiper switch
20 0005 : screen wiper switch
21 spare
22 spare
23 8010 : coolant temperature unit
24 1320 : engine management control unit
25 8025 : air conditioning panel (if separate)
26 0002 : lighting and signalling switch
Probably not much help but there's always the chance it'll give you a "hold on a sec" moment.
jimmy69
Post by jimmy69 »
hi, was this problem ever solved, because I have the exact same problem on my 51 plate 406 2.2 hdi gtx estate, also no fuel gauge not sure if this is related or just another problem. could someone give us a clue please, playing diesel roulette is not all its cracked up to be.
