Front Windows work - Back Dont!
Re: Front Windows work - Back Dont!
I know but the switches do play up, it was just an idea, I hit that thing like an idiot and it worked for 3 years after that :mrgreen:
Have they ever worked? Did you look at the wiring in the back doors yet?
Btw before I head off and look at wiring diagrams it's another in between car - is it com2000?
Right, I'm looking at the diagram for the pre-com2000 car and finding a relay that's turned on & off by the switch on the panel (it's a fecking pain because I can only see a bit of the screen at a time through the magnifier :frown: ) it also seems to have it's own fuse (27). Unfortunately the earlier diagrams don't tell you were anything is.Looking at the full mux diagrams... Ah, they have it too . it's one of the ones on the main passenger fuse box. It's saying the miniature relays on the top l/h end - however I suspect this is probably bollocks but I am physically unable to look under the dash on mine just now. Excellent, it's shown as coming off fuse XX :roll:
This might tie in with Welly doing rude things with his switch - it's not the switch he was working, it was the relay, so even if you try a good switch it's not going to do anything. You might be able to find the relay if you power the car up & gently turn the switch on & off whilst listening for it ticking. It should be somewhere around there...
