heater fans
- midsmike
heater fans
hi can some 1 help my brothers 406 99 saloon 1.9td glx heater fans stopped working wen he hits a bump they come on but go back off can any1 help as its getting colder
Re: heater fans
Mike,
I have the exact same fault on mine, it will be a loose/coroded connector running off the fan.
As yet I haven't located the exact wire but reaching across to the under the glove box and giving things a quick jiggle normally gets things working.
As you say it's getting colder so I'll be removing the blower and changing all the connectors when I've got time, mine was obviously kitted out for a taxi at some point so I have quite a bit of aftermarket wiring floating about behind the glove box
2003 2.2 HDI SE
2003 2.2 HDI SE
Re: heater fans
Just as an aside: I've removed miles of wiring from a few cars were they've had after market amplifiers, alarms etc. and not only are they often fitted in badly, they0ve been removed in such a haphazard manner that I'm surprised the car hadn't already caught fire. If I were you I'd have all that out, or at least make sure it's not getting ready to make a barbeque of you...
- midsmike
Re: heater fans
thanks ill have a look for him
