Key Fob (another question)
VespaSkin
Post by VespaSkin »
Got a fob from scrappy (double plip) what I was planning was (my car only came with the non plip one) - take blade and transponder out of the scrappy fob and use as a dangly addition to my orig key.. and idea if this is viable or will I spend 10 hours p1ssing about like I did last time to no avail? and if it is a goer, what's the best way to sync scrappy fob to my motor?
Thanx you guru's
Steve406HDi
1.6 8v
Re: Key Fob (another question)
Post by Steve406HDi »
If I understand correctly, you can't just resync a new key to your car. You'll need diagnostic equipment (pp2000) to do the reprogramming. I haven't successfully done it yet myself, although I plan to very shortly all being well. Just want to get my ECU fixed first but happy to let you know if I do manage to do it?
Peugeot 406 HDi 110 LX Saloon D9 110k miles, although dash now says 121k
Jobs list: Fix ECU, reprogramme stereo to stop the dreaded beep, reprogramme key to re-enable remote central locking.
Located: Leicester
midsdaz
Post by midsdaz »
How do u re sync a key to a d8 is it the same thing with d9s
VespaSkin
Post by VespaSkin »
Cheers for answer, I'm keeping the orig key and transponder that came with the car so don't need to code new key, what I was on about was taking the transponder out of the donor plip key and binning, getting rid of the doner blade and using it like you would an aftermarket remote fob - so have on my keyring; non plip key that came with the car, donor plip with no transponder and blade (only transponder it will read will be orig) and try and set up the central locking to read the signal from donor plip fob to lock the car, if you know what I mean?
I thought the main problem with new keys was the transponder as, for example, if you went to scrappy you would need, donor; key/s, corresponding transponder reciever (on steering?), ECU, locks etc... I was hoping that by keeping orig key I could 'fool' the central locking into thinking it has just lost sync 'cos it was reading that the orig transponder was present...
Sort of made sense to me, there again, I am a bit dim... :shock:
Steve406HDi
1.6 8v
I think I understand what you're saying: You're going to keep the non-plip, original key with the transponder in to start the car in the ignition, and use just the key body (with no blade or transponder) to blip the car's remote central locking?
In which case you will need to reprogramme the key fob. The transponder is only for the immobiliser, and the remote is a separate system.
I would take the blade and transponder out of your non-plip key, and put them into your new remote key, and reprogamme the remote part of the key to the car with Peugeot Planet. Then you'll have a working key with blade, transponder and plip.
Located: Leicester
VespaSkin
Post by VespaSkin »
Cheers... :mrgreen:
Steve406HDi
1.6 8v
midsdaz wrote:How do u re sync a key to a d8 is it the same thing with d9s
I'm not sure about the d8, I can check on Autodata when I get home but my guess would be it'll say 'programme key using diagnostic equipment'. Perhaps speak to someone nicely with PP2000.
Located: Leicester
midsdaz
Post by midsdaz »
If u could check that would be great it's driving me mad not have the button working
RE SYNC:
1. Turn the Ignition switch ON.
2. Press the large Plip key button (Primary Plip)
3. Within 10 seconds press the large Plip key button (Secondary Plip)
4. If there is one remote, press the Primary plip button twice.
5. Turn ignition OFF.
6. Test Plip’s for correct operation.
midsdaz
Post by midsdaz »
Sorry if I'm been stupid my key has the two buttons on it one for open unlocking and the other one for dead locking the car so wen I turn the ignition on I press the big button and release the within ten seconds press it again sorry again if I been dumb been a long day I have changed battery's and the red light does come on when pressed
Steve406HDi
1.6 8v
lozz wrote:RE SYNC:
Autodata agrees with Lozz for a D8, so you should be fine with these instructions. Yes press the large plip button twice then switch ignition off if you only have one key.
Located: Leicester
midsdaz
Post by midsdaz »
So I turn the ignition on press the button the within ten secs press it again the turn the ignition off ?
midsdaz wrote:So I turn the ignition on press the button the within ten secs press it again the turn the ignition off ?
yes :wink:
midsdaz
Post by midsdaz »
That didn't work tryed couple times and nothing when I press the button light comes on the goes off on the fob is that right or is it meant to stay on ?
There was mention of,
if they dont Re sync, take battery lead off, leave off 10mins
take battery out of fob, replace,
to reset everything,
dont know if it works tho,
