Has anyone ever tried fitting a instrument with oil-temperatur gauge, to one without ?
Models 2003 and forward have 5 dials in their instrument, mine only has 4. Would really like the last oil-temperatur dial.
Since mine is a 2001 model, would there be any chance that it would work.
If not, isn't the easiest way to install one via. The oil-plug and just wire it from there.
oil temp
- rwb
Re: oil temp
Instrument Panel Change
IIRC: the speedo has a different graduation on 5-clock dashes.
(BVA is French initials for automatic gearbox, BVM is French initials for manual gearbox.)
The other issue is that the new mileages will be messed up, but I can't remember the algorithm, e.g., whether the new dash adds it's exsiting mileage onto the car's mileage or what.
Re: oil temp
thanks! Although It dose not answer my question totally
I have the oil-leven indicator in my instrument, but I want the oil-temperatur gauge.
In regards the milages, it will always display the highest, so since my car has 305.000 miles in the ecu, it will be displayed into the instrument.
- rwb
Re: oil temp
Indeed. I'd like an answer toomoblaw wrote:Although It dose not answer my question totally
Maybe the answer is "try it and see"
Re: oil temp
indeed rwb.
that was my next task, but before that I'd still do some research and a headgasket + new head before I adventure out the in my car to the scrapper, to remove and test it before purchase perhaps.
