There are a couple of other minor faults that i would like to put right if anyone could shed some light.
The LCD milage display does not work and the right side of the instrument cluster is unlit. Clearly a bulb needs replacing to light the right side but am i right in thinking the LCD is seperate and replacing the bulb in the cluster will not light the LCD?
Another fault i found was trying to open the fuel flap. The lever down the side of the drivers seat, you can pull it and see the flap move out but when you let go it locks again. I have to wedge something under it so i can get to the partialy open flap and pull it open. Anyone else had this problem?
Only had the car since Sunday and so far this is all i have found. Apart from these it's a great car.
