I'm assuming it's a D9 (same headlights as mine ). Think they did the facelift in 2000??
So you need the engine compartment fuse box (as opposed to the one under the dash) and these are the headlight fuses;
Fuse# Rating Function
9 15A LH Dipped Beam
10 15A RH Dipped Beam
11 10A LH Main Beam
12 10A RH Main Beam
There's also the following note.....
the book of the words wrote:
The maxi-fuses provide additional protection for the electrical systems. All work must be carried out by a PEUGEOT dealer.
Yeah right, you even need the stealer to change a fuse.....
Ok what I will do is, scan in the Fuse box grids for both the D9 and the D8 models later on tonight and then maybe they could be sticky's on the forum for everyones reference.
[edit] ok here they are:
D9 Fuses:
Internal Facia:
Engine Bay:
D8 Fuses:
Internal Facia:
Engine Bay:
Ok well I hope that helps you out.
11 10A LH Main Beam
12 10A RH Main Beam
Sorry to be ignorant (or stupid) but the numbers you've specified here don't correspond to the screenshots of the car manual ...
On the second D9 model screenshot it says fuse #29 in the Internal Fascia is the LH main beam headlight. Is this dependant on the model, or am I missing something here ...?
Hey how weird is that? Maglite's D9 manual is different to mine.....
Now I'm confused
Just had a look at mine and it's definitely right for my car, so there must be different ones depending on model as you say
Very odd...
with regards to the owners manual, if you register your car at http://www.peugeot.co.uk you can download the complete manual for your car in pdf format...
