Hi Guys,
Driving around today in the 406 & mileage reading & trip display have
gone blank ! Idon,t know what,s wrong but i do have to hand a spare
set of clocks.It,s easy to change them over so if i put in the new clock
set what mileage will it read ? Is the mileage recorded in the ECU or
in the speedo head itself ? Anybody ?
Mileometer/Tripdisplay Problems
- DaiRees
Re: Mileometer/Tripdisplay Problems
I think the answer to that is both, and if you change the clocks the computer adds the mileage from the new clocks to the mileage in the car's ECU and you end up a very high readingOld Smokey wrote:Is the mileage recorded in the ECU or in the speedo head itself ? Anybody ?
Then again I might have dreamed that.......
- jameslxdt
its most likely the bulb, and Dai you are almost correct, if its a D9 then if you put a different set of clocks in then the BSi adds the current mileage to the mileage of the clocks fitted
- 1.6 8v
- 2.2 16v
Dash bulbs
It's always the backlight bulbs that go in my experience. Mine used to go every 6 months or so, which got me wondering if there are different quality bulbs that last longer?
