I fitted a new battery to my transponder this morning ( it wasn't working when I bought the car) and all seemed well as the fob locked the car as it should
I then went to unlock the car and it didn't work. all I got was the indicators and side repeaters flashing constantly at quite a fast rate and I had to use the key to unlock it in the end
am I doing something wrong or is there a fault somewhere?
it's a 2 button transponder if that makes a difference
Transponder help please
Re: Transponder help please
It sounds like you are pressing the lock button when the car is already locked.
Is the fob faulty? Is it all clean inside the case - no debris..??
the fob is all clean but buttons are missing so I'm pressing the switches under the buttons ( if that makes sense) at the mo
I've ordered a replacement casing for it but that won't be here until next week
I didn't realise that there was a separate button to lock and unlock the car. I thought it was all done through the largest of the buttons and the small round one was for something else
I'll go and try it in a bit
thanks
thanks
On a 2 button fob the large button locks and onlocks
the Small button is deadlock after locking with big button
Steve
Steve
Do you have a teardrop shaped key or the later ' fat triangle ' shape?
Mine is the later, so one button locks and the other unlocks, on earlier keys Steve is correct..
all sorted guys. thanks
it's the larger fob. the small button now works but I have to press it in with something. roll on next week when the New casing arrives
