PP2000 in use...
MixMan
PP2000 in use...
Post by MixMan »
Hi, I have just got hold of a PP2000 kit and after some :twisted: :twisted: :twisted: :twisted: getting it installed and running, I now have a question of experienced users...
When I do a 'Global test' some ECU's do not reply..
So I did a 'Test by ECU', but get the same result...
I have disconnected, rebooted the laptop and fiddled with the connections and checked all fuses in the car...
Any ideas folks, it's driving me nuts....
Currently frustrated by: 2002 2.2HDi Executive Saloon
rwb
Re: PP2000 in use...
Post by rwb »
It's not unknown.
Which ECUs didn't reply?
Did you pick the right 406 from the menu? 406 or 406R
And did you get your build code right?
MixMan
Post by MixMan »
Basically the only ones that replied were the engine - it told me I had the wrong ECU and the seats...
As far as the build code, I am assuming it is the largest four digit number at the bottom of the sticker inside the door shut...in this case making it 7766...
MixMan wrote:7766
Umm, Fri 13 Feb 1998 :?
Where's my sticker? viewtopic.php?f=18&t=19141&p=196775&hil ... er#p196775
rwb
Post by rwb »
MixMan wrote:7766
Umm, Fri 13 Feb 1998 :? [/quote]
That can't be right for any HDi
steve_earwig wrote:Where's my sticker? viewtopic.php?f=18&t=19141&p=196775&hil ... er#p196775
Haha my 407 is EXLD.
benczuk
Post by benczuk »
Its an 02 so make sure you choose 406R.
Your build code is this bit here:
