Changing A/C condensor
hammerman
Post by hammerman »
As title really.Have a 2003 HDI estate,found out today the condensor/rad is leaking.I can get a new one for around £25 cheaper & save myself £120 odd in labour if i do it my self.Anyone ever changed one?I assume the front bumper has to come off.And the system is empty now as the garage drained it to fill it with nitrogen & dye,so now worries about the gas etc.
2003 Hdi Est SE
Busman
Re: Changing A/C condensor
Post by Busman »
Yes, and it's fairly easy if you are competent to change the radiator. Taking out the headlights improves the access dramatically. Then remove the radiator mounting bolts which will let the rad tip backwards. then with some fiddling, the condenser can be accessed and removed.
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
Busman
Post by Busman »
P.s.
You live just up the road from me should you need a hand.
Doggy did a step by step guide in the knowledge base.
I can't post the link cos I'm on the mobile, but its there.... :cheesy:
viewtopic.php?f=10&t=7606
No need to remove the bumper, just the grille, slam panel and most of the skin from your knuckles.....
MixMan
Post by MixMan »
Mmmmmmnnnnn.....knuckle sandwich...... :shock:
Currently frustrated by: 2002 2.2HDi Executive Saloon
hammerman
Post by hammerman »
Great thanks a lot guys.will get on with it next week as IBM busy this weekend.euro car parts have them from £65-£80 depending if I have a dryer/receiver so will have to check.will keep you posted.
2003 Hdi Est SE
