No, that's the right diagram, it just doesn't make any sense -
6002 - right hand window lift front switch
6036 - driver's door electric window/mirror control pad
Surely they're the same thing? Although the connector on 6036 is 16-way so I'd think this is the control panel with all the switches, and 6002 is 7 way, maybe the passenger side switch?
Give up with that,
That's for a semi.mux but the switch panel is the same part number, unlike the full-mux it actually shows you what's going on inside the switch. Wire codes should be the same but if you need to know what they actually are I can look them up and post them.
Hope that helps!
I have to stop being anti-social now
edit: No idea why it's showing it twice, never mind
