what can i do?
i bought the indicator stalk with only the rear fogs and not both!
since i don't have rear fogs, is there anyway to make this work with my front fogs?
Ah, I get it, I'd still expect the lenses to be there, even if they're not wired up. Sadly, being a semi-skimmed the diagrams aren't all that. All I can tell you is you'll have to move it from pin 1B to pin 4B, I know that's not much help but I wouldn't trust a pin-put anyway. The connector is only 9-way so it shouldn't take long to figure out with a meter.
Mr Google says - Rear fogs have been a legal requirement on all new vehicles since 1986, if only 1 is fitted it must be on the offside or centre of the vehicle.
Assuming the majority of 406's were left hookers and assuming the law applies to the majority of countries it was exported to I suspect they're there but possibly not working.
Personally I'd be tempted to plug the new stalk in and see what happens, maybe pop the off side bulbs out and have a look how many bulbs you have.
My D8 had bulb slots both sides but only the off side wired up, presumably so the same parts fitted all models and only the loom changed.
2003 2.2 HDI SE
So what is rear fog?
And with parking lights on
As you noticed and as this is the first time i have opened this someone has jumpered this light have to find out why?
As my memory is pretty poor I always end up turning the lights on in sequence to work out which bulb is which, I'd detatch that wire first of all and see what's still working.
Not sure what you mean by parking lights but having 3 bulbs lit seems a bit odd if it's just side lights and the one in the bottom of shot is suspiciously bright.
Is your car a left or right hand drive?
2003 2.2 HDI SE
As you can see even the internals are different the wires are soldered onto diff pins
For that reason when i put the headlights on with out the rear fogs rear fogs come on.
Anyone know how i can eliminate the rears and use as front fogs? Not much of electrician but i have a multimeter now
