Simple question:
Will I need the Lexia 3 to use Peugeot Planet? I have already this OBD hardware, that can be connected via USB: http://www.ebay.com/itm/WIFI327-WIFI-US ... ls&vxp=mtr
If I need a Lexia 3, will this do the job? http://www.ebay.com/itm/Diagnostic-Tool ... ls&vxp=mtr
PP 2000 - will I need Lexia 3?
1987 Peugeot 205 1.9 GTi 8v
1999 Peugeot 406 2.0 HDI ST estate
- jonsowman
Re: PP 2000 - will I need Lexia 3?
Lexia is the Citroen version of Peugeot Planet. The hardware is actually called "PSA XS Evolution", and yes you will need it to use either PP2000 or Lexia 3. The USB OBD device you already have will not work with PP.
The one you've linked to looks fine, though the advice is often to buy it from a UK supplier in case of any issues. That said, I bought mine from China since it was a lot cheaper and it has been fine.
Thank you so much!
- jonsowman
You're very welcome!
- 1.6 8v
i had problem with installing my lexia Diagbox V7.57, help needed
- 1.6 8v
Well, nobody replied the question, i have to google it and get a valuable document
http://blog.obdii365.com/2016/05/08/ins ... box-v7-76/
