So this noise coming from the underside of my glove compartment when I start the car, not while its running or driving. It is more than annoying but what could it be?https://vimeo.com/137504466 Thanks
Sent from my iPhone using Tapatalk
What is this noise?
- peugeot30v6
What is this noise?
2002 Peugeot 406 V6 Auto Executive [95100miles]
2003 Peugeot 406 HDI 110 Executive Manual [157000miles]
2002 Volvo S60 2.0t Auto [287000miles]
Re: What is this noise?
It's probably the automatic selenoid to open or close the Wind Flap, or the flap itself it's stuck in something and it's trying to open, try pushing the wind deflector button and see what happens if the sound occurs again.
2000/May 406 Estate 2.0 HDI 110bhp DW10ATED now with 205k km & now with cruise control & now remaped @ 134bhp
- peugeot30v6
Thanks, I pressed the wind deflector button and it made the noise again. Will try again to see if I can get underneath.
Its a common thing - the motor that controls the flap is a matchbox sized motor with a flimsy brown cog which can strip the teeth.
The flap may also be stuck, it is possibly to 'gently' push the flap from outside the car - its under the pollen filter which is under the left hand scuttle panel, this panel just unclips but the clips are a bit fragile.
