Enquiring if anyone in my district has a Lexia?
Northampton home. Warwick/Telford work.
I would like to install cruise control to my 2003 110 HdI.
I have checked:
The presence of the red connector for the extra brake light switch - OK
The Clutch pedal switch already fitted - OK
The port in the steering column Comm2000 unut with contact strips for the control stalk - OK
What I understand I need to do now is to read the ECU to check that cruise is available / can be enabled.
If all good, Install switches and control, enable and Bingo!
I hope it is that simple!
So, if you have one and would be interested to help with this, I am happy to come to you and reward you suitably for your participation.
