Hi There,
I have just purchased a 406 Executive Estate. I have just purchased a instrument cluster off eBay for £0.99 and went to collect it as it was only up the road. When I got it home I thaught it would just plug in. Unfortunatly it appears that my car is the older version (White & Black Plug) and the one I brought is a later single black plug LED type one. I was wondering if I can retrofit the later one into my car as I would like to purchase the white dial, chrome bezel one out of a later S or SE car (which should in theory have the same single black plug as the one I have just purchased). I plugged it into my car and although the instruments worked
Peugeot 406 Fuel filler cap warning light (N/A)
Peugeot 406 Door open warning light (DOESN'T WORK)
Peugeot 406 Dipped beam headlamps indicator light (DOESN'T WORK)
Peugeot 406 Main beam headlamps indicator light (DOESN'T WORK)
Peugeot 406 Rev. counter (WORKS)
Peugeot 406 Left-hand direction indicator (DOES WORK)
Peugeot 406 Central (STOP) warning light (DON'T KNOW IF WORKS)
Peugeot 406 Low fuel level warning light (DON'T KNOW IF WORKS)
Peugeot 406 Fuel gauge (WORKS)
Peugeot 406 Service indicator, oil level indicator and total distance recorder (WORKS, ALTHOUGH DOESN'T ILLUMINATE PROPERLY)
Peugeot 406 Right-hand direction indicator (WORKS)
Peugeot 406 Speedometer (DON'T KNOW IF WORKS)
Peugeot 406 Clogging of the particulate emission filter warning light (Diesel) (N/A)
Peugeot 406 Front fog lamps indicator light (DON'T KNOW IF WORKS)
Peugeot 406 Rear fog lamp indicator light (DON'T KNOW IF WORKS)
Peugeot 406 Dynamic stability control (ASR/ESP) warning light (according to version) (N/A)
Peugeot 406 Low coolant level warning light (DON'T KNOW IF WORKS)
Peugeot 406 Coolant temperature indicator (DON'T KNOW IF WORKS)
Peugeot 406 Trip recorder zero reset button (WORKS)
Peugeot 406 Handbrake and low brake fluid level warning light (WORKS)
Peugeot 406 Seat belt not fastened warning light (according to version) (N/A)
Peugeot 406 Airbags warning light (WORKS)
Peugeot 406 ABS system warning light (WORKS)
Peugeot 406 Engine diagnostics warning light (WORKS)
Peugeot 406 Battery charge warning light (WORKS)
Peugeot 406 Diesel engine preheating indicator light (WORKS)
Peugeot 406 Passenger air bag disarming warning light (WORKS)
Peugeot 406 Water in diesel filter warning light (WORKS)
Peugeot 406 Front brake pad wear warning light (WORKS)
Peugeot 406 Engine oil pressure warning light (WORKS)
Peugeot 406 Electronic immobiliser warning light (DON'T KNOW IF WORKS)
Peugeot 406 Lighting rheostat (DON'T KNOW IF WORKS)
Peugeot 406 Engine oil temperature indicator (WORKS)
Also the sidelight panel lights work when the sidelights are swithched on. As mentioned above, the odometer illumination doesn't work.
I don't know if the LEDs are kaput or if they are powered off the white connector.
Any help apprieciated and also diagrams between the two would help. I have a spare black plug off a scrap car so can splice this one in as it plugs into the connector on the cluster.
I was just wondering if anybody has previously done this mod and if it was successful.
Many thanks
Ben
Instrument Cluster Help
Re: Instrument Cluster Help
It will not be the cluster gauranteed
