Hi, I got a MFD display with faulty backlight. Bulbs are ok as I checked them, even replaced all 3, even replaced the 3 white bulb holders.
Checked the bulbs with multimeter, all good. I also checked the board that host the bulbs and there is no voltage.. there should be 12v but my reading show 0. I checked the fuses under the steering wheel and could not find anything faulty or out of order...
MFD is I believe type B with 2 buttons and 3 bulbs from behind it. It shows time/date and outside temperature which some time after the backlight broke stopped showing any reading. At first it started to show some random values like 50 degrees celsius, later stopped working completely and now just show "--" I believe this has nothing to do with backlight issue and just need a new temperature sensor, but one never knows.
I also replaced radio with sony shortly after I bought the car and the original broke down, but the backlight used to work ok for long time after I changed the radio. The issues with backlight started when 1 of the little backlight bulbs blew. I replaced it and it worked for a day or so, then suddenly went black. Since then I was not able to fix it, but the display still works, just hard to see anything as it is dark.
Are there any other fuses that could have something to do with the backlight of this panel?
Any other ideas what could I try?
