You should be able to wire the plug as per the red inked image in my description on page one and the pinout on your Ripca relay case.
Steve's excellent relay link is all you need for extra info but if you really are in doubt I suggest you seek someone with a modicum of electrical know-how
to do the job for you.
BSI air con relay replacement.
- Newbie
Re: BSI air con relay replacement.
Hey, my 2003 406's BSI is different than this one, so i can't locate the relay for the compressor, any help?
- Newbie
I've got a similar issue,
got the 2003 406, which has the Valeo BSI.
Any guidance on where to find the AC relay on the Valeo BSI?
Any hint would be greatly appreciated.
