Hi , has anyone used this bsi exchange service advertised on ebay
https://www.ebay.co.uk/itm/Plug-Play-PS ... 634-2357-0
Bsi repair service add on ebay
- 1.8 8v
Re: Bsi repair service add on ebay
you want to clone you old bsi
- 1.8 8v
It has a mind of its own , locks the doors as soon as the key is turned ,go used to that but as it flashes the hazards every time someone walk by think we will be left with a flat battery somewhere , and we have been told that it is a main dealer job , and its not worth what they will charge to repair it
- 1.8 8v
you checked all the wires under drivers carpet . my hdi had a problum and it was there bad wires in plug . if not you can have bsi clone . you need number off bsi . to find one with same numbers on , then it can be cloned
- 1.8 8v
No I havent will have a look at the weekend ,the cill drain is ok though , our first 90 estate had a wet floor should have looked before now , thanks
