1.9 TD Rev Counter Stuck
av8tor
1.6 8v
Post by av8tor »
About 70% of the time I'm driving, the rev counter needle is not working, stuck at about 1900 RPM. When it does randomly decide to work it seems a bit off. I did a search on the forums, but I couldnt come up with a clear solution. I'm a complete novice as far as mechanics go, so if you know the cause, please be gentle in explanation! Cheers!
Jeff
jameslxdt
Post by jameslxdt »
take the tdc sensor out of the top of the gearbox, its black and under the thermostat housing and is held in with one 10mm bolt and give it a good clean with brake cleaner and a rag, and fit it back
av8tor
1.6 8v
Post by av8tor »
Thanks James! I cleaned the sensor, and everything appears operational thus far... Cheers! :cheesy:
Jeff
