Horn Problem... Help guys
Harshan
2.2 16v
Post by Harshan »
Hi All,
This happened to me few hrs ago while I was driving my D8 it started hooting nonstop the horn. it was annoying to the crowd around 'n i got out from the car to indicate thats a problem. It was continuously honking for abt minute and i tried press the horn button and nothing worked. all of a sudden it was gone and now there's no horn at all.. any help ?? any suggestion to check? where the horn relays and horn fuses are located ? thanks in advance
jameslxdt
Post by jameslxdt »
not sure where the relay is but this it is almost certainly this thats causing your problem
Could also be the switch in the stalk - it would cause the same symptoms albeit on a different circuit. However the relay will be easier and cheaper to rule out so go for that first. I think it's under the fusebox, but I don't have a Haynes to hand sorry. If you haven't got a Haynes manual, you should really consider getting one :)
Harshan
2.2 16v
Post by Harshan »
found the problem.. one of copper contacts inside the stalk has broken.. have to replace the entire stalk electrician suggested not to repair the broken contact
Harshan
2.2 16v
Post by Harshan »
