Bit Confused
chill3r
Bit Confused
Post by chill3r »
Hi People
as the topic says i'm kinda confused about something with my 406
when i bought it the guy explained to me that the keyfob didnt work and everything runs off the key etc - i dont have to put a code in - he advised that it didnt need one and he didnt have one anyway
the car drives and everything works ( apart from the A/C LCD Screen)
i'm just wondering if everything should be ok - dont wanna be out far and i cant get back home :cry: :mrgreen: - also wondering if anybody else has this setup key only
wouldnt mind trying to get the keypad and fob working - but a little scared incase i mess things up
V6Exec
Post by V6Exec »
There are two basic variants of the 406 and three basic key types:
D8
Two button remote key combined with coded panel. Big button locks/unlocks; the little button activates deadlocks.
On my D8 the remote had a fault and did not work - had to do the doors the old fashioned way :cry:
D9 - Key type 1
Key looks and functions like a D8 key but has a coded chip in it.
My current D9 has this style of key.
D9 - Key type 2
Key looks and functions differently. The big button locks the small button unlocks. It also has a coded chip in it.
To be able to answer your question a bit more info would be helpful. What year is you 406?
chill3r
Post by chill3r »
its a 96 P Reg
V6Exec
Post by V6Exec »
96 P = D8
There was a thread covering the imobiliser without code on this board.
It was something like. Put in code; start engine; unplug keypad; no more codes :cheesy:
It seemed to be safe.
jameslxdt
Post by jameslxdt »
not on a diesel, there are two other ways, a bit of rewiring, not recommended or remove the pump, drill out the stop solenoid shield, cut out the immobiliser unit and run a 12v ignition fed supply to the stop solenoid
jameslxdt
Post by jameslxdt »
have a look at this thread
chill3r
Post by chill3r »
cheers guyz - on investigation from my local mech friend - he has advised that this is whats been done so no worries
thanks ladz
