BSI on D8's? Wiper fault
Tiny Tim
Post by Tiny Tim »
Right... do the D8's have this BSI unitI keep reading about?
My 2.1TD ('97) has an annoying wiperfault I cant trace. - Normal wipe works, no Intermittant or Fast wipe.
Relay is fine (replaced for new), stalk seems to be ok as I tried another known working unit to no avail and im ruling out the motor as normal wipe works.
Any ideas peeps?
darrenwall
Post by darrenwall »
the D8 doesnt have a BSI thankfully but i had problems with the wipers on my 2.1td D8 and it was the sensor on the windscreen for the rain sensitive wipers that wasnt working and it was affecting the intermittent wipe , has yours got a sensor by the rear view mirror ?
Tiny Tim
Post by Tiny Tim »
Very much doubt it, its an LX!
I'll have a look tomorrow and report back though.
Tiny Tim
Post by Tiny Tim »
Nope, no rain sensor that I can see. Any other ideas anyone?
check the wiring diagram in the haynes. think you may find it's the motor broken though as i think it does all the shiz internally like stopping at the end of a single wipe, doing intermittent wipe, etc
Tiny Tim
Post by Tiny Tim »
OMG im actually gonna cry.
Bought a used motor and switch from a scrappy and still no joy. Yes, they could be broken, butnow I cant find my damn tester to find out where the current fails. AARRGGHHH!!!! :evil:
mjb wrote:check the wiring diagram in the haynes. think you may find it's the motor broken though as i think it does all the shiz internally like stopping at the end of a single wipe, doing intermittent wipe, etc
There's usually tracks in the motor and brushes on the lid, when the supply is turned off or on single wipe there's one supplying 12 volts to the motor all the way round 'til it gets to park, where another track gives the phase an earth which stops it spinning - unearthed wipers often don't park, they go slower but have usually have enough momentum to carry on up the screen and off we go again.
I notice my rain sensing wipers can switch between intermittant, slow and fast so I'd reckon the relay/control box would be the best place to look. Hopefully the connector's come loose...
Tiny Tim
Post by Tiny Tim »
i'll double check the relays. what do you mean by control box?
I reckon there's too much in it to call it a relay
jameslxdt
Post by jameslxdt »
make sure you changed the correct relay, im sure its blue and has about 5 to 7 pins on it
