D9 fusebox layout
dado
D9 fusebox layout
Post by dado »
what is it with peugeot D9 fusebox diagrams both haynes and my car manual show where the fuses are located in the passenger compartment fusebox Wrong !! they seem to bear no relation to the individual fuse location I give up ford seems to be beckening :x to me
GeordieBoy
Post by GeordieBoy »
They are under the steering wheel, loosen the 3 plastic screws and it drops down to reveal the fuses.
Hopefully you will find what you are looking for, Peugeot have a habit of hiding other fuse boxes around the car mind.
Vehicles I own:-
dado
Post by dado »
yes sorry didnt mean that im dull i meant the fuses on the diagram do not correspond to the fuse numbers in the fuse box Doh :?
jameslxdt
Post by jameslxdt »
its not peugeots fault, haynes fail to take into account the severe amount of wiring changes that have taken place through the manufacture of pugs
The wiring diagrams in the D8 Heinz say "typical", I'm used to them not being very accurate since cars gained more than 2 fuses... I don't think it's their fault either, Peugeot (et al) make so many alterations they'd have to print a different book for almost every car.
