Purchased Hella 50 mm H7 halogen projectors (95 eur/each) from Tm Tuning because I want to use H7 xenon kit with them.
I couldn't disassembled projector's lens and reflector parts.
New ECE headlights, H7+H7
Workin on it
H7 rebased 4100K (from autolamps-online):
Custom made base :
Painted projectors :
Don't want to cut back of reflector ...
Left headlight was retrofitted first , for test ...
Left : halogen FF reflector with H7 kit, right : halogen DE projector with H7 kit :
Cut-off and pattern of hella halogen DE module only (with kit)
Light distribution is very wide, and there ise a yellow line on the center of cut-off
I must calibrate up-down level of new headlights, I think no need for right-left level.
Need suggestions-opinions, thank you !
