fuel gauge (or lack of)
Post by 110 »
hi,came to work tonight and fuel gauge reading three quarters,pulled the car in to the warehouse for the night and suddenly fuel gauge only goes up into the red and fuel light is on and low fuel warning on display.have checked for leaks but bone dry.put £40 in last night....any ideas chaps?
thanks. :(
Re: fuel gauge (or lack of)
The float's fallen off the end of the sender?
V6Exec
Post by V6Exec »
110 wrote:put £40 in last night ... came to work ... fuel gauge in the red
That sounds like a regular day for me and the V6 :cheesy:
406 Coupe S HDi
PP2000 clone interface
110
Post by 110 »
thanks guys,looks like it`s a trip round the garage tomorrow ,is the sender a swine to get at then?.
Actually, looking at haynes, there's only one feed, so presumably the light isn't a separate contact but put up by the dash ecu when the gauge drops. The sender is also part of the fuel pump ( :shock: ) so not something you want to mess with without checking owt else first. Apparently, you can get to the pump through a cover under the back seat, I'm still not sure about the wiring though, Haynes is typically vague. I think the best you can do is pull the connector off, then turn the ignition on and see if the light still shines, if it goes out then it's the sender, if it stays on then it could be anywhere!
Bluddy overcomplicated cars, maybe I should give up and buy a horse...
110
Post by 110 »
well i just started the car in the warehouse and the gauge very slowly went up to the half way mark and now when i switch off and on it goes to that mark and i can see the needle very slightly swaying..strange.
however when i gave the top of the dashboard a good thump the fuel gauge illumination went out along with the door open light and the headlight on indicator and they all came back on with another thump :shock: .
french wiring eh :lol:
I'm down to 300 miles for £70 of fuel... erk.
V6Exec
Post by V6Exec »
It would take driving like a granny to get up to that :D
406 Coupe S HDi
