The 2.0 HDi 110 Xsara (2002)engine light has come & it's in "Limp Mode",(I know it's a Citroen but same difference).
The diagnostics is saying "Glow Plug Relay Fault" but it seams to be working OK, Any Ideas?
I can't understand why a glow plug fault would put it in Limp Mode, if they didn't work how could that harm the engine?
Engine light on/limp mode
406 HDI Exec Estate (2 off) & 307CC HDI Cabriolet
Re: Engine light on/limp mode
Mine said glow plug curcuit but it was the radiator fan drawing to much current on it's wiring
The ECU codes are a bit missleading. I would say throttle position but to be fair this normally recovers by itself. The crank position sensor can also cause problems.
Where's James?
Where's James?
