I finally got around to installing my new electronic boost controller on my 406 turbo exec over the long weekend (a very cool unit which lets me not only control peak boost but define the shape of the boost curve, and has two maps) which obviously meant disconnecting the boost control solenoid from the ECU to wire it up to my project. But now I've got a fault light, which I guess makes sense as if the ECU can't see the solenoid it must think there is no boost control?
Anyway, someone else on here must have done a similar thing before. Is that most likely why I'm getting a check engine light? If I wire a high wattage resister across the old wires with the same impedance as the solenoid will that fool the ECU, or should I turn to the scrapyard to find another solenoid to use as a dummy?
And no, before anyone asks, I'm not boosting anywhere near 1 bar so the fault light isn't because I'm exceeding the map sensor resolution.
