engine starting from cold
terryh
Post by terryh »
engine start from cold is a real problem . just about to fit new fuel filter and clean injectors on my 2ltr glx . do you think this will cure the problem
Re: engine starting from cold
Do you mean that it's idling rough or taking a long time to actually fire up?
terryh
Post by terryh »
It's taking a long time to start up .it does eventually after about 20 seconds or so of key turning moments.
Sounds like fueling or sparks to me; also the TDC sensor has been known to go faulty.
Are the leads & spark plugs in good nick?
terryh
Post by terryh »
hi glx has just had new plugs supposedly and fuel filter so going to try them again see what happens .as for sensors never seen so many. wished i hadn't bought a petrol car.
