Write all your sensor problems here. Please :D
406Break
Post by 406Break »
Hi all,
I'm interested in any sensor related problems that you have encountered on your Pugs :)
And please tell how did the problem present itself.
Mainly petrols :)
Thanks all
Peugeot 406 Break - 2.0L - 99kW - EW10J4/RFR - BVM5 - VF38ERFRE80937145
jasper5
Re: Write all your sensor problems here. Please :D
Post by jasper5 »
I have only encountered two sensor faults over the last couple of years.
First was my own car, 2001 HDi90, the fault appeared as a high temperature on the temp gauge, STOP light coming on at motorway speeds, then only intermittant, leading to permanent STOP light on.Fault was the green coolant sensor on the right hand side of the engine, under and behind the air filter box.
The other was a customer's car, engine management light on intermittantly, sluggish acceleration, lack of power, hesitation.
My mates scanner read, "fuel system lean", further tests showed zero voltage from the Lambda (oxygen) sensor, a new sensor fixed the fault.
wasn't there a thread just like this a couple of weeks ago?
406Break
Post by 406Break »
If there is one already, then I'm sorry. :oops: :(
mjb wrote:wasn't there a thread just like this a couple of weeks ago?
Don't remember seeing one :?
It would be useful to have a list of all the sensor faults that have cropped up.
stevenlizuk
Post by stevenlizuk »
Faulty engine temp sensor made mine rev by itself as the fuel pump rammed loads of fuel into an already warm engine.
(2.1td)
She cannae take it captain!
Proud owner of the Funbus 98 2.1td estate being reborn £70 at a time.
Still need new back-plates.
