d9 front pad sensors not working
- 1.8 8v
ive just replaced my front brakes pads and discs but the old 1s were right down and the light should have come on but didnt so i tried testing it and cant get the light on with bridging the wire to earth is this circuit fused or has some 1 had this trouble before
Re: d9 front pad sensors not working
Looking at HBol, feed comes via the stop lamp switch - they're only, 'live', when you press the brake pedal.
does anyone know where the wiring for these connects to in the main loom as both of my front ones have had the wires cut or snapped and tried to trace it back as far as i could in the scrap yard and gave after undoing all the battery box and fues box and un wrapping the loom as far back as near the master cylinder on the pass side one!
and is the wires shielded due to the thick trunking on it?
