Code: Select all
1 - 6563 31 - DISPLAY (FXT - BLACK CORNELIE)
2 - 6563 02 - REMOTE CONTROL
3 - 6563 C8 - GPS AERIAL
4 - 6563 R7 - BOX
6 - 6563 37 - BRACKET
8 - 6563 38 - AERIAL CABLE
10 - 6563 48 - NAVIGAT TRANSFO
70 - 6927 08 - SCREW CBX (DIAM 6X100-20)
I suspect that both the standard and sat-nav capable MFDs use the same type of connection, but I can't confirm that as I've never taken the MFD out of either of my cars.
Also - I don't know what the "Navigat Transfo" thing is on the diagram above.
Once you have all the bits and fitted them in, and you've checked and confirmed if you need a fuse (and have fitted one if you do) and it still refuses to work, then it may be a BSI thing.
Hope the above is useful to you.
