I have two switches in front of me, from the brake pedal I believe. One is normally closed and one is normally open. one has a red plug and the other has a white plug, but as they aren't fitted to the car I was guessing which was which. So the brake light switch, white connector, is held open until the pedal is pushed, closing the circuit, and the cruise switch, red connector is held closed until the pedal is pushed, breaking the circuit. The clutch switch, I haven't found yet, has a brown connector. I'm still trying to unravel the loom to see what is what.
mjb wrote:stealthe wrote: If you have the wiring for the clutch pedal just wire the two switches in parallel, the switches are 'open' with no pressure on the pedal and 'close' when the pedal is pushed.
You sure about that? If you pull the brake light switch out with the ignition on, you'll see the brake lights illuminate...
I tested the wrong switch.
Do you mean that if the brake light switch is unplugged the brake lights come on?
stealthe
**Edit**
All three switches are fed from fuse 3 in the fusebox by the driver, they are spliced together near the bulkhead seal. After passing through the switches, the wiring for the brake light goes to the bsi, and the brake/clutch pedal cruise wiring passes through the bulkhead, to the ecu I guess.
