Posts: 10710 Joined: Mon Oct 13, 2008 11:49 pm
Post
by Doggy » Fri Jan 14, 2011 5:11 pm
Does anyone know for certian whether the Snap-On gadget will definetly talk to an HDi - not many things will?
(Though I seem to remember one of FarmerPug's countrymen suggesting a big hammer definetly would talk to it).
2003 HDi 2.2 6 -speed Exec Estate (2012-19) (also a gem)
Posts: 19813 Joined: Thu Oct 04, 2007 6:09 pm
Post
by steve_earwig » Fri Jan 14, 2011 5:38 pm
lionyo wrote: ...I changed the 10 fuses.
10? There's meant to be 18
Looks like 4 & 5 supply the connector on the schematics.
lionyo
Posts: 99 Joined: Sun Nov 01, 2009 5:11 pm
Post
by lionyo » Fri Jan 14, 2011 5:42 pm
steve_earwig wrote: lionyo wrote: ...I changed the 10 fuses.
Sorry for the confusion but i meant the 10a red coloured fuses
Dogslife you mention that the snap on tool may not communicate with the HDi?
Post
by steve_earwig » Fri Jan 14, 2011 5:50 pm
Ok, they're both 10a.
No idea, if not had to plug in to my Pug yet (something I need to check I guess) but I do believe they're not very friendly.
lionyo
Post
by lionyo » Fri Jan 14, 2011 5:58 pm
steve_earwig wrote: Ok, they're both 10a.
Very frustrated at the momment, makes me want to buy my own computer that I can plug in and use.
Post
by Doggy » Fri Jan 14, 2011 7:44 pm
That's what I did - got one of
these
Not cheap, but I reckon I've saved what it cost me easily by now, not to mention peace of mind.
There's about 5 or 6 forum members with one of these now - if you add your location, someone nearby might help.
lionyo
Post
by lionyo » Fri Jan 14, 2011 7:56 pm
dogslife wrote: That's what I did - got one of
these
I am located in Birmingham if some one is kind enough to help me out it would be appreciated.
lionyo
Post
by lionyo » Fri Jan 14, 2011 8:47 pm
I just went outside to reconnect the battery and saw that their was a lose connection just below the battery as picture below is the answer for the engine management light, air pollution active being on?
Also my central locking is not working after I disconnected the battery.
Posts: 5315 Joined: Sun Mar 28, 2010 9:56 pm
Post
by Gary406 » Fri Jan 14, 2011 9:06 pm
check the main earth points from the battery, follow the neg wire,
d8s are usually under the battery try
d9s at the side of the fuse box
lionyo
Post
by lionyo » Fri Jan 14, 2011 9:21 pm
Gary406 wrote: check the main earth points from the battery, follow the neg wire,
Anyone explain what that wire could be?
Post
by Gary406 » Fri Jan 14, 2011 9:27 pm
follow the neg wire that connects to the battery ...
take the battery back off and follow it and check were it connects to the body ,,,
lionyo
Post
by lionyo » Fri Jan 14, 2011 9:34 pm
Gary406 wrote: follow the neg wire that connects to the battery ...
Hi,
Okay I'm not a mechanic but love a bit of a challenge so I will take the battery off and have a poke around to see where it goes.
Wish me luck and if someone knows where it pacifically goes then I would appreciate your input.
Once again thanks for all you contribution and help chaps.
Posts: 9656 Joined: Tue Jun 01, 2010 5:42 pm
Post
by FarmerPug » Sat Jan 15, 2011 2:45 am
a pp2000 will talk to a hdi.
FarmerPug on Sat Jan 15, 2011 10:19 am, edited 1 time in total.
Post
by Doggy » Sat Jan 15, 2011 9:55 am
You might be able to find it on
here
My car seems to have the a connector in the same area - I have a plug & socket wiring from one disappears under the headlight, below the dip beam bulb area. Wiring from the othe half of the connector goes through to the radiator / condenser. I tried disconnecting it to see what doesn't work:
It's not the foglights, doesn't seem to be the horns, wiring's too small to be the radiator fan.
Mine had a green/yellow wire plus probably a white one - I couldn't make out numbers on either.
lionyo
Post
by lionyo » Sat Jan 15, 2011 6:06 pm
Problem solved
Finally the dreaded engine management and air pollution fault have finally gone, the plug that connects to the denso thing was loose and I put it back on and when I started the car it was still on so I set off to go to the garage and when I travelled down the road it went off.
Well chuffed just need to get the remote fob working
