2.2 Hdi Anti pollution fault & engine management light
lionyo
Re: 2.2 Hdi Anti pollution fault & engine management light
Post by lionyo »
dogslife wrote:I don't mind giving it a try for you, but be aware I haven't carried out this operation before.
I'm fairly certain the procedure entails resetting the counters, then adding a minimum of 15 litres of diesel, (presumably to trigger an additive injection), then possibly doing another reset, (Instructions are displayed on PP2000 during the operation).
Where abouts are you based mate I'm in Birmingham?
Also it still hasn't got full I put around 4 litres what you recommend I put some more in?
lionyo wrote:[Where abouts are you based mate I'm in Birmingham?
NN17...
That should be enough for a year or two, so I wouldn't bother.
FWIW, I still recommend deleting the FAP, it's cheaper and you'll never have to revisit it.
lionyo
Post by lionyo »
I had a friend who kindly put the car on his "snap on" computer and reseted all the fault codes but the light came back on after a minute. He tried it 2-3 times.
Does reseting the counter mean clearing the fault codes?
No.
I imagine all you're doing like that is resetting the faults reported by the engine ecu.
If it's been low on Eolys, the additive ecu will still report a problem until it's had it's two counters reset, had some fuel added and gone through a successful additive injection sequence. (May also have to completed a successful FAP regen too, as I said earlier, I've not 'done' one so I'm not sure).
lionyo
Post by lionyo »
Bit of a update...
Just thought I'd let you peeps know I managed to get everything sorted and the dreaded low additive message has been cleared.
I had it reseted yesturday but the light came on again so I put 10 litres of fuel in and took it for a motorway run but had no luck, then the next day I bought more additive fuel as I only put around 3 half-4 litres topped it up then plugged onto the computer reseted counters and hey presto all was cured :cheesy:
By the way really appreciate your inputs dogslife!
stubart
Post by stubart »
Hi Lionyo.......
im having the same issue resetting counters......
how did you cure the issue....
i filled my eolys tank then a chap on the forum tried to reset counters but its not playing ball....
i can get it re mapes and rip the interior out of the fap filter.....but as i have paid £138 in fluid to fill the tank its bugging me.....
but if i cant get the filter light to go out i will have to de fap it.....
one fustrated coupe owner.....Stuart
