Sat Nav
Hi everyone, a Pug 406 newbie here. (Upgraded from a 106...)
I've just bought one a 2002 406 with Sat Nav but I too am getting the message 'CD unreadable'. Can someone please let me try an alternative CD because I really don't want to shell out for a relacement Sat Nav player if I can avoid it.
How do you clean the CD player without damaging it? Can you use a standard CD lens cleaning kit?
Much appreciated.
Much appreciated.
- jameslxdt
have you taken the cd out to see what its like, the disc readers have a nasty habit of filling up with water so you may just need to clean the disc
- jameslxdt
through the rear lights, they have a habit of leaking very badly
Thanks Gus and 406Express for the help. They didn't work so I think the unit needs cleaning. I purchased a Fellowes CD/DVD lens cleaning CD/DVD from Tescos which features 4 small brushes close to the disc index but the instructions say to select track 2 which obviously I can't do. Needless to say the damn thing still won't play the Nav CDs.
Can anyone please recommend a kit that is compatible with the Sat Nav unit and actually cleans??
I have no more hair to pull... well I do but I ain't pulling them...
Lasers can be a bit of a pain. If you are very lucky ( and I mean VERY lucky) you may be able to insert the disc so that the brush on the cd brushes near the lens when you insert it. You could also try a can of air in an attempt to blow any debris off the lens.
Ideally, you want to be able to see the laser and with a cotton bud and some alcohol clean the lens. This would involve some dismantaling though? Unless it can be seen through the slot? (I very much doubt it though)
This is about the only option that is left open to you mate.You could also try a can of air in an attempt to blow any debris off the lens.
have a look here
http://www.dabs.com/productview.aspx?Qu ... ationKey=0
this may help but i think they can be obtained cheaper.
