seat removal when electric not working?
gray
Post by gray »
This is fuse box under bonnet
This is the bsi
Gray
2000 D9 2.0 litre RFV saloon
Re: seat removal when electric not working?
A more useful picture would be of the fuse panel next to the BSI...
When you say all these fuse positions are empty, did you try adding a fuse? There is the possibility that the previous owner removed the fuse because maybe it blew all the time or they used it for something else.
Attached wiring diagram but I suspect it will not tell you anything new.
gray
Post by gray »
Fuse box under steering wheel above bsi
Gray
markw
Post by markw »
On mine, the seat fuses are where your 2x 20A Yellow fuses are...are you reading the fuse positions ok?
My fusebox is rotated 180 degrees but I guess that's because you're left hand drive maybe?
That appears to be this fuse panel
Note the unmarked spares on the left of the 2nd row.
Nothing I have matches up to the fuses I'm seeing there :frown:
markw
Post by markw »
These are the seat fuses on mine...
That looks pretty close to me! Apart from the upside-down thing of course :roll: (psst, got a diagram? :supafrisk: )
markw
Post by markw »
:?: To what Steve :?: I only have SEDRE same as you!
Ah, didn't know that (crystal ball on the blink) I was hoping maybe you had found a diagram for yours.
Before I go off on safari, did you look on passion?
gray
Post by gray »
so i removed the fuses and swapped them and the passenger side still works fine. so that tells me that both fuses are fine. must be some where after the fuse block because there is power to both fuses as i check with a tester light.
thanks for your help Steve and Mark
any suggestions?
Gray
Puggy2
Post by Puggy2 »
Hi I have just looked at Vivid Workshop & fuse 10 30amp is seat memory system & fuse 11 30amp is passenger seat & fuse 13 30amp is drivers seat. Fuse 15 20amp is also seat position memory. Give this a try. Iain
gray
Post by gray »
Puggy2 wrote:Hi I have just looked at Vivid Workshop & fuse 10 30amp is seat memory system & fuse 11 30amp is passenger seat & fuse 13 30amp is drivers seat. Fuse 15 20amp is also seat position memory. Give this a try. Iain
Puggy2 is this the fuse panel under the steering wheel or under bonnet?
Gray
markw
Post by markw »
The quick answer gray if you're not sure is to lift every single fuse you can see one at a time and check it.
A pain I know, but at least there'll be no ambiguity.
gray
Post by gray »
markw wrote:The quick answer gray if you're not sure is to lift every single fuse you can see one at a time and check it.
what you guys have told me all checks out fuses are fine none are missing where they should be i have changed with other fuses that are good and still the drivers seat does not have any power to it, to the motors, the switches, the memory switch, or any junction under the seat. i have checked every fuse slot for the seats and there is power going to them. so there must be a break somewhere between the fuse panel and seat. but i cant move the seat to get at the bolts to get underneath it. im kinda stuck in a hard place :evil: and have done a bsi reset as well
Gray
