Airbag fault (D9 semi-mux)
Re: Airbag fault (D9 semi-mux)
Does it bring the light up if you set the whole lot to absent? I bluddy hate having airbags :frown:
Wire cods:
650 : Driver's pre-tensioning seat-belt + command
651 : Driver's pre-tensioning seat-belt - command
652 : Passenger pre-tensioning seat-belt + command
653 : Passenger pre-tensioning seat-belt - command
654 : seat belt fastened warning lamp control /
655 : driver's pretensioning seat belt and strap return control +
656 : driver's pretensioning seat belt and strap return control -
6500 : Driver's air bag 2 control 2
6501 : Driver's air bag 2 control 2
6502 : Passenger's air bag 1 control 1
6503 : Passenger's air bag 1 control 1
6504 : Passenger's air bag 2 control 2
6505 : Passenger's air bag 2 control 2
6506 : Driver's side airbag + command
6507 : Driver's side airbag - command
6508 : Passenger side airbag + command
6509 : Passenger side airbag - command
6510 : 1C Airbag 1C info
6511 : 1C Airbag 1C info
6512 : Driver's knee airbag + command (these might not actually be all on the diagram but I got fed up going back and forth)
6542 : front air bags warning lamp control /
6544 : side air bags warning lamp control /
6546 : Passenger airbag neutralisation switch info
6547 : Passenger airbag neutralisation command
6708 : Bridging solenoid valve command :? eh? It's 6508 the other end, spot the cock-up :roll:
Thanks for all your input gents. The car and it's owner have gone off to bemoan the impossibility of the situation to all who will listen, (and a few that put up a spirited fight), while yours truly tries to figure out how this became MY problem. :roll:
Next thrilling episode at the weekend, weather permitting. Just this, a number plate light and a drop link to do - what could possibly go wrong. :?:
Well, it's sorted.
In the end I cured it by unplugging/re-plugging the multipole connector at the airbag/pretensioner ecu under the centre console. What a joyous experience that is - you have to dismount the ecu to undo the plug, because it's too sodding close to the handbrake lever to fully separate. :evil:
It still only talks to one of the two side airbag ecu's, and the one that responds reports an open-circuit warning light....
Decided that can of worms could wait.
FWIW it doesn't look like you can disable any or all of the system on a semi-mux
Thank's everyone for the info and suggestions, much appreciated. 8)
