Having got home I decided to get my head around the vacuum system so I was sure what everything did. I found that the turbo vacuuum hose had come off. I also found that the swirl valve hose had been taken off and plugged. I already knew the SV actuator was broken. So I then ripped all the vacuum hoses out and now I have one blanked off at the pump end and the two connections at the servo end feeding the swirl and turbo.
Have yet to replace the turbo hose at the turbo and also still to fit SV actuator because I'm poorly and it's raining
Will then be looking to tidy up the doser and heat exchanger pipework.
