Quickest thing to check, then ;) It must be one circuit through the door lock and the bulb and then going back into the car / bsi and a blown blub then causes an open circuit.Doggy wrote:Some 406 saloon / estates have - the higher spec ones, GTX, Executive, SE, possibly some others.
Being a V6, the OP's car may well have them so definitely worth checking.
One door no longer triggers the interior lights
- 1.6 8v
Re: One door no longer triggers the interior lights
Coupe 2.0 EW10 manual, Prins VSI LPG, galileo green
Coupe 2.0 EW10 manual, Vialle LPG, polaris blue
Coupe 3.0 ES9J4S automatic, settant anni no. 0076, hades grey
I do have lights in the door cards, so I'll have a look at the bulb. Easiest way to check it will be to open any of the other doors, since all of them turn on together. I guess fiddling with those wires may also be part of the trick if it is a contact issue.
Thanks.
Thanks.
Not that easy, unfortunately....
Light bulb lights up when any other door opens up. Also, wiggling the wire bundle does nothing. I guess there's not much choice left but to access the locking mechanism...
