New battery, but do I need to take precautions?
Re: New battery, but do I need to take precautions?
Or at least give you a lift in his Pajamas to get one :frown:
The original pug battery seems to just slowly run out of steam over a week or two whereas other cars I've had suffer with a cell going down and flattening the whole thing in minutes! sometimes whilst parked up normally.
Have you tried the old key re-programming sequence Supa?
Put key in ignition.
Press and hold big button.
Turn on ignition (while still holding big button).
Wait 10 secs.
Release button, turn off ignition, take key out and test.
Either smile and say "That nice Dai bloke is the font of all 406 knowledge" or throw the key at next door's dog while shouting "That f***ing clown on the forum knows nothing!"
Bugger! Sorry soops. :frown: Did my spare key that way just recently 'cos it had stopped working, works fine now.
rapport25
Location: either in my Audi SQ5+, X- trail Aventura or Mini Cooper Cab
Post by rapport25 »
Dai is spot on. Supa that should work :o
I would suggest try holding the big button in turning the key in the ignition from off to on but dont start the car.
Also try pressing the big button on and off while turning the key in the ignition.
Also try starting the car while pressing the big button.
Switch off remove key and lock it with you inside that should sort it.
If it works I will take dai's title :oops: :oops: :oops: :oops:
If not sorry :cry: :cry:
Seems the 2002+ models are even more stupid than the older D9's :roll:
I literally just changed the battery, didn't keep anything 'live' whilst doing so and had no trouble at all (1999 model).
I reckon you'll end up down the Dealers Soops for some sort of software/BSi thing.
supafrisk wrote:Basically I think the plip's sh@gged.
Try some new batteries just in case though!
Edit: Come to think of it, Split the key apart and put it back together in case the key needs to be powered down or something stupid!
Have you still got both keys, Super :?:
Plipping ek!
Try this version of the procedure.
http://www.programyourkeys.com/Peugeot_ ... tions.html
It does make a kind of sense - if you have two keys do one then the other, if you've only got one, then you need to do it twice as the car expects two operations to complete the sequence, (I think).
Saw another similar sequence, which said if your car's got deadlocks, you need to operate both buttons at the same time.
Hope one of these works, (I'm heading for the embarassed corner with Dai just in case).
I think they just mean if you've got 2 plippers then one is the Primary (main) and the other is Secondary (spare) tha's wht they say "press the plip twice" if you've just the one plipper!.
Pipping ek!
Still think you'll end up at the plipping dealers though!
Have you thought about asking an alarm fitting place?
