new pp2000 owner questions plz
Re: new pp2000 owner questions plz
i wish sorry i'm just outside newcastle upon tyne around 200 miles away
. i'm starting to think a earlier version may be needed but it worked spot on the lads 2 citroen's. iv'e a v6 version
2.0hdi lx 51 plate 90bhp chassis no.VF38BRHYF81371125
hi all ive uploaded a video for you of more knowledge to view can you give me any ideas plz
http://s1172.photobucket.com/user/brian ... 9384725627
Sorry Brian but that's not the same as my start up page & not like any other's I have seenbriangoo wrote:hi all ive uploaded a video for you of more knowledge to view can you give me any ideas plz
go to you tube & search for pp2000 set up / install guides.
2006 BMW e61 535d m-sport
run's for cover
my version worked fine on 2 citroens which the computer guy who sorted mine owns (a c2 & a berlingo). On youtube there is 1 that shows someone doing it to a 406 coupe which it says coupe 406 no fault found on each global test. But on the auto gearbox & suspension it says the ecu has not replied but it does pop up that because his car doesn't have these things it won't find the ecu just like what mine says on each test. So i'm still at a loss
ADMIN:::: I think what's needed on this forum is a separate section with each version of pp2000, so each person can look up theirs & put their videos on either youtube or photobucket to help others if poss
just tried a friends 2.2 with a airbag fault & guess what same thing
. now I notice the lead that has the round multiplug pins seem very delicate but if it wasn't ok it would come up no communication I guess. does this plug ever give bother
need I say any more
hi al back again & still no luck
does anyone know if you can use v6.0 on a windows 7 computer as i'm sure I seen a 1 working on youtube but I can't find it any more
Also i'm coming down to pontins southport at the end of this month if any of you kind fellows with more wisdom can help from down that way i'd be forever grateful
hi again
still no luck does the 30 pin plug go into the 406 anywhere to see if that helps at all maybe my 16 pin diag port is playing up ??????
or is my version working fine on citroen but not on peugeot
I'm about an hour from Southport if you are down this way later this month, or you could call here on your way or meet somewhere if it's any help to you.
You could detour from the A1 to the A59 on your way to Southport depending on which way you intend to go....either way i'm on your way to Southport.
Can you pm me or post if you please your town thanks
Brian,
You say you've had it working on two Citroen's but no Peugeot's, sounds to me like you've got the Lexia working & nothing else, Lexia is for Citroen only.
Start afresh uninstall all of it DO NOT INSTALL Lexia or Diag box this is for newer Peugeot's only install pp2000 for now to make sure it's fully working.
I'll email you the guides my I.T buddy used, pm me your email.
Regards Dirty.
Regards Dirty.
run's for cover
Hi its brian.goodman at blueyonder.co.uk thanks
Reason: you like spam or wot?
any updated to resolve this problem?
I have the same problem, PP2000 can't communicate with the vehicles.
after enter build code, it always shown messages "switch on ignition" and "connect portable to connector 001"
if I do global test, all the ecus not replied and the grey screen.
I bought 3 set of clones PP2000 which no one working
, even with other peugeot.
I don't have any idea, the interface which fault or the software or my XP
a new update for for my pp2000 in november i met with jasper5 who used his pp2000 which worked a treat
. so he loaned his disc & i got mine wiped & his installed to my comp it took forever to get done cos the guy was ill busy bla bla. any way just tried it & no luck. now before the whole lot goes on ebay cos iv'e had enough
my chassis no. is VF38BRHYF81371125 can anyone check service box plz for my DAM number. i did register to use it but iv'e lost the log in details to do it from my end iv'e tried 09012 & 0901 whiich i'm sure it is. but no luck ps just renewed the abs sensors & it's great now
09012 - full-mux (just!)
Okay it looks like it's going on eBay then or if anyone wants it on here so be it
