Heated mirrors or not?
Pugman406
Post by Pugman406 »
Hi guys
I have a 200 x-plate 406 glx.
Can anyone tell me if it should have heated mirrors or not? My old mondeo had them and they worked when the heated front screen was activated, so wondered if the 406 does the same when the windscreen blower button is activated?
D9 2.0 HDI, 406, GLX, 110
eoin27
The Irish 406 addict
Re: Heated mirrors or not?
Post by eoin27 »
It should have them as standard on a glx d9.
They come on with the rear window demister. I think...
Pugman406
Post by Pugman406 »
ahh right, in that case they are not working, is there a fuse for them, if so, where and wot number wud it be plse?
I don't think there's a separate fuse as they take the +ve feed directly from the rear heated window switch.
Would be worth popping the mirror glass off; you should have 2 leads connected to the mirror glass. The tags do become quite brittle going into the element but they can be soldered back on if you can clean them up enough. Also check for 12v on the leads with the rear demister turned on!
plod
Post by plod »
Would a 99 D8 GLX have these - just one of those things I always wondered with my car
1999 D8.5 HDi GLX - Sold :(
Pugman406
Post by Pugman406 »
i shall have a look when i find a spare few minutes.
Cheers
