since getting the car I have noticed that my clock and climate control display is really dim to the point where I can hardly read the displays
I'm assuming that it is blown bulbs, are they easy to replace, or could it be a fuse maybe blown?
Cheers for any info
Interior displays
Interior displays
D8 2.1 TD saloon, oh yeah
- Site Admin & Mad Biker!
Re: Interior displays
Blown bulbs, they are not that difficult to change; same type of bulb as the dash takes.
The clock just levers out & you can access the bulb.
For climate control: Remove blanking plate to left of rear heated windows switch and remove screw, remove trip computer (or tray depending on trim level) and remove screw.
Pull radio out and you'll see another two torx screws behind it on either side securing the climate control unit.
With these removed you can pull it out and get to the bulbs
