drivers electric window problem
barryemm
Post by barryemm »
hi guys have a slight window problem on my 2000 hdi 110
drivers side window control buttons 2 arent working the 2 rear ones work but the 2 front ones dont passenger one works with passenger switch but not with drivers side ive read that its the drivers window control module thats buggered
window is opened and cant get it closed anyone any ideas how to get the window back up without controls
barryemm
Re: drivers electric window problem
Post by barryemm »
well bought a switch from my local scrap yard was working on the donar car but the front drivers and passenger window arent working but the 2 back ones are along with the electric mirror all the wires are ok the front passenger one works fine with the passenger control anyone any ideas whats wrong
gtanswell26
Post by gtanswell26 »
im having a very similar problem on mine just bought a window regulator and tried that but all i seem to get is a buzz from the drivers door but no movement
both my front windows do not work and im wondering if it could be a relay or something but not sure where the window relay is
to get the window up i took the cover off the window motor and wound the shaft to put the window up (4 torx screws just under the plug connector)
takes ages tho
as for the electrical problem im stumped
jasper5
Post by jasper5 »
I had this problem quite a while back with my driver's window, I found that the switch was actually reversing.....the switch was sending the window DOWN every time you pressed the switch, that is why it was stuck at the bottom.
I did manage a temporary repair, but a new switch solved the problem.
BTW, an easy way to get the window back up is to undo the bolts holding the window to the mechanism (the regulator) and push the window all the way up, then cable tie it in position until you fix it.
barryemm
Post by barryemm »
gtanswell26 wrote:im having a very similar problem on mine just bought a window regulator and tried that but all i seem to get is a buzz from the drivers door but no movement
takes ages tho
take the rubber bit off in between the door and look for broken wires mine was just a broken wire
