New Car - grief already - any ideas?
HI,
I just got a 97 2.0 Petrol Exec 406.
I have the following problems:
1) The AC went from working fine - to working intermittently - to not working at all in two days! I have a feeling that the dealer may have regassed it the day i went would this fit in with what happened if there were a leak?
2) The STOP light has come on permanently with no other lights! What does this mean (I dont have the manaul) can I drive it? Can I read the fault codes?
3) The rear passenger window opens again when it reachers the top - how can I reset the windows system?
Any suggestions or help would be much appreciated!
Scott
Scott
Does a road sign that says Stop mean Stop?
The STOP light means stop. For want of a better expression. It usualy indicates some sort of engine critical fault. A low level of some important fluid, or an electronic issue.
But just to show you its not all bad, I have a 1996 N reg LX. 2.0 litre. And as everyone on the foruim will tell you, with 179K miles on the clock, she's never given me any grief beyond the usual stuff that every car gets. Leaks, tyres, echaust etc.
Re: New Car - grief already - any ideas?
Try turning the ac function off. Still no cold/hot air? Then me $0.2 say you have an engine cooling problem.scottpsouth wrote:HI,
Scott
Land of the Free?
As for the stop light, I had that on my 206 and the garage told me to
take the battery off for 30mins to reset the ecu. It worked warning light
never came back on.
never came back on.
Vehicles I own:-
Vehicles I own:-
I had a problem with my a/c - the connection to the one of the fans was dodgy and nothing would work. Re-made the connection and it's been fine ever since.
Radiator fans are in Battery Fusebox 2, Fuses F6 and F7 (says 20/40 Amp).
Passenger fusebox Fuse F21 says Air conditioning/Heating Ventilation, it's only 10 amps..
scottpsouth wrote:Hi,
Fans were completely dead. Replaced and working fine. Everything else sorted as well. It runs at <90 degrees now. Bit worried that I might have damaged something before (ran at 100 degrees and once or twice went up to 110)
Cheers
Scott
Nah, thats fine. Its that red bit at the right side of the guage you want to avoid.
My car settles at between 80 to 90 when moving and climbs to 100 when stationary. Its been to 110 before on a very hot and humid day in Germany, stayed there for a wee while too.
Fault Code Reader
My 406 HDI 110 (2000 Wplate) has an OBD2 Socket to the right of the steering wheel behind the black panel. I got a reader from http://www.ukobd.co.uk for ?35. It will let you read the codes for some problems but not all (won't do P codes). Diesels only had to be OBD2 complient from 2003.
For the same price as it costs to get a garage to read it I didn't think it was a bad deal, plus it confirmed the Fault the Garage identified (380 - glowplugs, 220 throttle sensor) when the ecu light came on shortly after I got the car.
If it's a serious problem and the car's not running right I'd still go to a garage and get them to download the fault codes.
